jonatan Posted March 5, 2009 Report Posted March 5, 2009 anyone know whats the diff from:Class bd circuit topology to Adaptive class D circuitry how do you know what makes a good mono amp? Quote Kenwood Excelon DDX812 6.95" double din 4 lvl 4 xl 15" 4 RF 1500 2 RF 600.4 2 15-MC5 - Memphis 5.25" 2 Way MClass Coaxial Speakers 2 15-MC92 - Memphis 6 x 9" 2 Way MClass Coaxial Speakers 2 mc memphis tweeters memphis 16-EQP4 Signal Processors 4 2400 Kinetik 1 1800 Kinetik iraggi 300 http://www.stevemeadedesigns.com/board/ind...showtopic=42009
troy Posted March 5, 2009 Report Posted March 5, 2009 (edited) a company with a good rep or cea compliant is a good place to start Class D amps have higher efficiency, produce less heat, and draw less current than Class AB designs. Class D amplifiers do have higher distortion than AB designs , but this distortion occurs at high frequencies that are typically removed by a low-pass filter. So a d amp is probbably the best choice for a bass aplication Edited March 5, 2009 by troy Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
jonatan Posted March 5, 2009 Author Report Posted March 5, 2009 a company with a good repcea compliant Class D amps have higher efficiency, produce less heat, and draw less current than Class AB designs. Class D amplifiers do have higher distortion than AB designs , but this distortion occurs at high frequencies that are typically removed by a low-pass filter. So a d amp is probbably the best choice for a bass aplication so bd is same as ab? Quote Kenwood Excelon DDX812 6.95" double din 4 lvl 4 xl 15" 4 RF 1500 2 RF 600.4 2 15-MC5 - Memphis 5.25" 2 Way MClass Coaxial Speakers 2 15-MC92 - Memphis 6 x 9" 2 Way MClass Coaxial Speakers 2 mc memphis tweeters memphis 16-EQP4 Signal Processors 4 2400 Kinetik 1 1800 Kinetik iraggi 300 http://www.stevemeadedesigns.com/board/ind...showtopic=42009
troy Posted March 5, 2009 Report Posted March 5, 2009 no d circuitry and ab circuitry is two different things. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
jonatan Posted March 5, 2009 Author Report Posted March 5, 2009 no d circuitry and ab circuitry is two different things. no i said is bd and ab same Quote Kenwood Excelon DDX812 6.95" double din 4 lvl 4 xl 15" 4 RF 1500 2 RF 600.4 2 15-MC5 - Memphis 5.25" 2 Way MClass Coaxial Speakers 2 15-MC92 - Memphis 6 x 9" 2 Way MClass Coaxial Speakers 2 mc memphis tweeters memphis 16-EQP4 Signal Processors 4 2400 Kinetik 1 1800 Kinetik iraggi 300 http://www.stevemeadedesigns.com/board/ind...showtopic=42009
troy Posted March 5, 2009 Report Posted March 5, 2009 (edited) they still are not the same. its like asking if 2 and 5 are the same. class d is diff from ab regardless. its either one or the other not both where did you see a class bd amp? Edited March 5, 2009 by troy Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Guest Posted March 5, 2009 Report Posted March 5, 2009 cea compliant doesnt always have to be CEA compliant to be good. sundown iirc isnt cea compliant but its a damn good product. Quote
troy Posted March 5, 2009 Report Posted March 5, 2009 doesnt always have to be CEA compliant to be good. sundown iirc isnt cea compliant but its a damn good product. no buts its a good start to see if the are or not. it guarentees they put out what they rate. but sundow has a very good rep so that was the other example i gave Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
jonatan Posted March 5, 2009 Author Report Posted March 5, 2009 they still are not the same. its like asking if 2 and 5 are the same. class d is diff from ab regardless. its either one or the other not bothwhere did you see a class bd amp? here http://www.rockfordfosgate.com/products/pr...S&p_status= Quote Kenwood Excelon DDX812 6.95" double din 4 lvl 4 xl 15" 4 RF 1500 2 RF 600.4 2 15-MC5 - Memphis 5.25" 2 Way MClass Coaxial Speakers 2 15-MC92 - Memphis 6 x 9" 2 Way MClass Coaxial Speakers 2 mc memphis tweeters memphis 16-EQP4 Signal Processors 4 2400 Kinetik 1 1800 Kinetik iraggi 300 http://www.stevemeadedesigns.com/board/ind...showtopic=42009
troy Posted March 5, 2009 Report Posted March 5, 2009 a hybrid basically. its basically a way of saying its a mono amp with a very clean signal. being that is what a class ab amp does. they produce a vey clean signal. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
