How Do U Know Mono Amps Are Good What The Diff
anyone know whats the diff from:Class bd circuit topology to Adaptive class D circuitry
how do you know what makes a good mono amp?
Kenwood Excelon DDX812 6.95" double din
4 lvl 4 xl 15"
4 RF 1500
2 RF 600.4
2 15-MC5 - Memphis 5.25" 2 Way MClass Coaxial Speakers
2 15-MC92 - Memphis 6 x 9" 2 Way MClass Coaxial Speakers
2 mc memphis tweeters
memphis 16-EQP4 Signal Processors
4 2400 Kinetik
1 1800 Kinetik
iraggi 300
http://www.stevemeadedesigns.com/board/ind...showtopic=42009
a company with a good rep or
cea compliant is a good place to start
Class D amps have higher efficiency, produce less heat, and draw less current than Class AB designs. Class D amplifiers do have higher distortion than AB designs , but this distortion occurs at high frequencies that are typically removed by a low-pass filter. So a d amp is probbably the best choice for a bass aplication
Edited by troy
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
cea compliant
so bd is same as ab?
4 lvl 4 xl 15"
4 RF 1500
2 RF 600.4
4 2400 Kinetik
1 1800 Kinetik
iraggi 300
no d circuitry and ab circuitry is two different things.
no i said is bd and ab same
4 lvl 4 xl 15"
4 RF 1500
2 RF 600.4
4 2400 Kinetik
1 1800 Kinetik
iraggi 300
they still are not the same. its like asking if 2 and 5 are the same. class d is diff from ab regardless. its either one or the other not both
where did you see a class bd amp?
Edited by troy
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
doesnt always have to be CEA compliant to be good. sundown iirc isnt cea compliant but its a damn good product.
no buts its a good start to see if the are or not. it guarentees they put out what they rate. but sundow has a very good rep so that was the other example i gave
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
here http://www.rockfordfosgate.com/products/pr...S&p_status=
4 lvl 4 xl 15"
4 RF 1500
2 RF 600.4
4 2400 Kinetik
1 1800 Kinetik
iraggi 300
a hybrid basically. its basically a way of saying its a mono amp with a very clean signal. being that is what a class ab amp does. they produce a vey clean signal.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
  • Who's Online   1 Member, 0 Anonymous, 1762 Guests (See full list)
