XS Power
CURRENTLY I HAVE 2 OPTIMA YELLOW TOPS. I WAS DEBATING SWITCHING TO KINETIC OR POWERMASTER BUT I AM GOING TO TRY POWERMASTER.
WHICH BATTERY FOR UP FRONT AND WHICH FOR THE BACK ? I HAVE 2 ROCKFORD FOSGATE T1001BD AND A T4004.
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
well, you want to try to get the biggest you can and can afford. so measure your space up front, and get the biggest, and if you can afford a 3100 for the rear that'd be optimal, if not its ok.
example
i have 4-5kw
Big 3
250A Alt
4 runs 1/0 to rear
(2) 3100 in rear
and i still get (from 15v) a drop to 12 ish volts...
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
im runing 3800rms and i have 3 powermaster D925s, big3, 200A alt, and MLA
and at full tilt at idle i drop to the mid 14v from 15.5v then at full tilt at 2krpms i dont go under 15volts...
but for sure get the biggest you can fit and wat your wallet will let ya get.
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
I KNOW I CAN FIT A D3100 IN THE BACK I MEASURED UP FRONT AND I HAVE 8 HIGH 7DEEP 12INCHES WIDE TO FIT IN THE FACTORY BRACKET BRACKET
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
ok then if you can afford the 3100 get that...then look at the list of batts and find the biggest one that fits in your factory location....
and take your caps lock off.
Wiring-Memphis
what what the mla module do i just ordered a alt from dc power
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
if you have like 8.4 inches of height, then you can go bigger (D2700), but if not the D3400 would work out good, upfront
http://mechman.com/store/product_info.php/...products_id/317 (if you have only 8" of height)
http://mechman.com/store/product_info.php/.../products_id/30 (if you have alil more then 8" heigh)
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
cool i think if i fabricate another hold down bracket i can get some more high . i know the car takes a group 35 optima up front the group 34 didnt work because my factory power couldnt reach the terminal
thanks for all the help
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
np
ntm you can get terminal extensions if they dont fit.
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
  • Who's Online   0 Members, 0 Anonymous, 1803 Guests (See full list)
