sodfamily Posted March 5, 2009 Report Posted March 5, 2009 Is there a rule of thumb or anything out there that says if you have X watts on your sub (rear) you should have at least X watts up front to balance it out. I hope this isn't a stupid question, but it has been bothering me for some time. A couple of local shops say it dose not matter. But to me it seems that if you have 2000watts on the subs and would think you want decent power up front so they are not being drowned out. Head Unit: Alpine CDA 9887 Sub Amps: 4 RF2500's Subs: 8 SA-12's Walled Comp Amp: 1 RF600.2 (for now) Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters Batteries: (1) XS D5100 (5) D3100 Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star) Alternator: Dual Mechman Rhino 250's Deadener: Fatmat / Damplifier Pro
Ray Posted March 5, 2009 Report Posted March 5, 2009 power is irrelevant, efficiency ill play the role there along with displacement of the drivers. for instance I have 2400rms on my subs 2 12's and have only front stage 6" 4" and tweet running 160rms per side, and mine sounds very balanced. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
raytard Posted March 5, 2009 Report Posted March 5, 2009 i, on the other hand, have 1500rms to subs and 600rms to front stage (2 sets of components), it sounds great used to be 1200rms to 2 sets of components, a coax, and 4 super horn tweeters, which sounded pretty darn good as well,, but it was more screaming highs and less SQ obviously if you have nuts power to subs you need something up front to balance it, just work and see what you can get away with. hell, 4 4in rockford power coax off of deck power kept up with 1200watts of subs halfway decently in my car, but 600 watts and 2 sets of components is sooooooo much better Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
sodfamily Posted March 5, 2009 Author Report Posted March 5, 2009 Thanks guys that helps me out. I wanted to do either a Sundown 100.4D or a RF T400.4 and either one would be pushing a pair of MB Quartz RVF210 and a set of MB Quartz 164 add a sub for a three way setup... Head Unit: Alpine CDA 9887 Sub Amps: 4 RF2500's Subs: 8 SA-12's Walled Comp Amp: 1 RF600.2 (for now) Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters Batteries: (1) XS D5100 (5) D3100 Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star) Alternator: Dual Mechman Rhino 250's Deadener: Fatmat / Damplifier Pro
creyc Posted March 6, 2009 Report Posted March 6, 2009 This is an impossibly complex question to answer. Here are a few reasons why. Musical "tastes". What sounds good to you? I doubt most bassheads would be satisfied with a "flat" response as measure by an RTA. Speaker type, quantity, and system efficiency. 2-way mids and highs? 3-way? Passive, active? Crossover points and subsonic will play a HUGE role. Some subwoofer setups are setup to play from 80Hz down. Some from 50 and down..likewise with the midbass. Where do they pick up? Ultimately it will be something you'll need to experiment with and find out for yourself. Worst case scenario, just buy more power than you need and adjust till it suits your tastes. I personally enjoy retaining my near perfect hearing, so I don't even TRY to match my mids and highs with the bass. 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck
