Pioneer~Saturn Posted March 9, 2009 Report Posted March 9, 2009 (edited) Hey guys, I havent really posted anything on these forums...so Im going to post up a little work Ive done from time to time...The name's Doug and I design and build plenty of enclosures, shipping all over the country. I compete in db drag and will be upgrading the setup in my sig this summer to something a bit more intense Liking what I see here thus far. Anyways, enjoy.. This build will have a kerfed port, double baffled, and countersunk. Specs come to: 2.857 cubes before driver displacement 33Hz tuning 37 sq inches of port Here's a sketch-up of it: And it begins.. Pieces cut.. Back going on.. Side's turn.. 45 degree insert for the corner at the end of the port.. Edited March 9, 2009 by Pioneer~Saturn Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted March 9, 2009 Author Report Posted March 9, 2009 Kerf piece cut.. Mocking it up.. ^not perfectly lined up, but you get the idea.. Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted March 9, 2009 Author Report Posted March 9, 2009 Ready to mount the kerf piece Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted March 9, 2009 Author Report Posted March 9, 2009 Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted March 9, 2009 Author Report Posted March 9, 2009 Cleaned up for carpeting.. Carpet time.. Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted March 9, 2009 Author Report Posted March 9, 2009 Done.. Chyea.. Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
eliassami5 Posted March 9, 2009 Report Posted March 9, 2009 wow looks really good and clean, why didnt you curve the edges of the l7 cutout tho. You should put the sub in so you can see how it will look. Other than that great build...but GOT DAIMN you've got a lot of clamps lol Quote 91' Jeep Cherokee - The Heep Just Empty Every Pocket 96' Volvo 960 - The B◘x [sPL_4_U] HiFonics - Alpine Pioneer - Clarion Infinity - Kicker KnuKonceptz
Pioneer~Saturn Posted March 9, 2009 Author Report Posted March 9, 2009 Thanks, and I know I need to make a template that I can use for future builds with everyones square subs And yea, I have a decent amount of clamps Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
