Well ive had my 18" FI SSD for about a month
now and im very impressed with it. beats the hell outa my
truck but my box is having issues. The 12" port wall is now
flexing and is making a lot of port noise now its screwed to the baffels
but just glued everywhere else.
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
dont really have the option to rebuild it
at the moment anyways i can renforce it rite now
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
UH, rebuild it, and make it stronger next time.
x2
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
Id rebuild but for the time being lay some glue and clamp/screw it together...
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
i do plan to rebuild but seeing how its -30 out everyday here
i just want to fix it so it sounds good again.
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
bump
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
run a brace from the inside of the port wall straight across to the other side, tying it in to the other two braces if you can
assuming you dont have like a heated garage or whatever fiberglass wrapping them together wont work, and glue will take days to dry, but put it there anyway and run a bigass screw straight thru
glue is stronger then screws, remember that, gob that shit on there and throw a screw in the end just to hold it in place while the glue dries, def bring it inside and maybe throw a heatlamp or whatever on it so it cures before you bring it back out
Team DC
okay thanks guys because it really sounds bad and i cant give any demos
for friends because of it
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
