Mechman Alternators
Need More Idle Output On A Budget?
Can I still use my stock belt with this pulley? Or is a smaller belt needed?
Most vehicles will use the stock belt, but it is always a good idea to put a new premium belt on to increase belt grip on the pulley. That will improve the overall performance of the alternator under a load.
Is there a certian brand of belt that you recommend? How do you feel about the Goodyear Gatorback belts?
2 DD 9515
1 Soundown SAZ-3000D
2 Optima Redtops
Big 3 upgrade
Hitting 151.1db
Good year gatorbacks are good, so are Gates "green stripe" belts.
I reccomend squeezing on the shortest belt that you possibly can so that the spring tensioner is as far back in its travel as possible, that is usually 1/2 - 1" shorter than stock, but every vehicle and belt varies a little. Guess and check is the best method to maximize your belt tension on a serpentine setup.
