justinqualls1 Posted March 13, 2009 Author Report Posted March 13, 2009 what is price running on the dat2500.1 ive been thinking about trying them out but just wasnt sure about them yet. but i figured the test result showed they where pretty good
Noob_On_Droid Posted March 13, 2009 Report Posted March 13, 2009 I got around 2800w at 1ohm at 12v and haven't meAsured since upgrading electrical. It will handle .5 ohm and push your subs plenty hard :-) If you want to shoot me a PM just search noobtastic14 so I can see it when I get back on a computer, damn BlackBerry
justinqualls1 Posted March 13, 2009 Author Report Posted March 13, 2009 and would it be safe to run it a .5ohm or would i have to run it a 2ohm and if so what is rms at 2. And ok Noobtastic14 and it will run at .5ohm safely ?
DHFHades Posted March 13, 2009 Report Posted March 13, 2009 what is price running on the dat2500.1 ive been thinking about trying them out but just wasnt sure about them yet. but i figured the test result showed they where pretty goodI believe they are 799...not 100% sure thoughsorry, they are just a little over 700 1990 Jeep Cherokee 4X4 Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp DAT HF1000.1 #007 powering a DC lvl4 15 DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active 1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest. rebuild coming soon to get a better score "I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
Ben Building Posted March 13, 2009 Report Posted March 13, 2009 If you are running the Optidrive 1532D, then I would highly recommend the AP 30001D. It is a dual monoblock, meaning it actually has two 1500watt RMS monoblocks inside of it; each stable to 1 ohm. This explains why the amp is so sexy (over 30 inches long), but also helps when it comes to powering dual two ohm subs like the OPTI 1532Ds. You can wire one 1 Ohm (dual 2 Ohm coil) sub per side of the amp. As I recall, the 1532D handles 1300 watts RMS, so look for them to give you all they've got on that amp. Trust. Also, out of all the amps mentioned so far, the AP 30001D is among the best bargains price wise. Since you're running Lanzar subs, I'm assuming you're like most of us and want bang for the buck. Go with the AP, and, with proper installation, you will NOT be disappointed.
justinqualls1 Posted March 13, 2009 Author Report Posted March 13, 2009 i pretty decent at installs and am usually the person everyone calls when they need help with there systems lol so i know what im doinig pretty good. but anyway i was thinking that also i just dont want it to be to bad. i currently have one of the 15" hooked up to the opti 1400d amp and it slams pretty good so i was hoping doubling the power and amount of subs that it slams good
Ben Building Posted March 13, 2009 Report Posted March 13, 2009 With both double the power and cone area, your a whole lot louder than before. Your 1400D is actually a pretty good amp. Have you considered just getting another one to add to your second 15 when you get it? I happen to have had very good experiences with the '32' series optidrive subs and that that amp is a good match for your sub.
justinqualls1 Posted March 13, 2009 Author Report Posted March 13, 2009 yeah i was thinking about getting another one of those amps but i thought if i got one with a little more power it wouldnt hurt. but tuning it to be exactly the same on both of them seems to be a little hard but i could be wrong. ive just never done that before.
Ben Building Posted March 13, 2009 Report Posted March 13, 2009 The Opti 1400D is strappable, meaning you can avoid all those two amp headaches by simply strapping two amps together. Together, they would be stable to 2 Ohms, which is what your subs wire down to series/parallel. But even if you wire one amp to one sub, it is not super-critical that you set both amps' gains together; that only applies when you connect two amps to the same sub. I agree that those 1532 speakers can handle a little bit more power though. Also, there are the new '33' series Optidrive subs that handle 3000 watts RMS each at a good price if you have space limitations.
justinqualls1 Posted March 13, 2009 Author Report Posted March 13, 2009 I cant find anything saying that those amps are strappable. But yeah these subs can take a little bit more than that amp but that sounds like a pretty awesome new subs. i havent seen them yet. but anyway thanks for the help man i just still a little confused about the straping thing but other than that im guessing that ap3000.1 is prolly my best buy as far as i see but other than that idk lol
