cool thanks. quick question St.Ides i know it may be a little off topic but what gauge wire are you using for your power and ground? some places says the amp can take 4 gauge and others say it can take 0 gauge :unknw:
Team Bass-Hz
on the site it says it takes 4 guage
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
Guest KyleCannon
There is no way this amp can take 0 gauge unless you strip wires off the end where you took off the jacket. 4 gauge to this runs it just fine. Trust me :D
Exactly what Kyle Cannon said. 0 gauge will not fit unless you trim some threads off the wire.
I'm using 4gauge power/ground on this amp
Edited by St.Ides
TNCB
....my damn room was shaking, im like wtf is this how am i gonna die jakin off to vida guerra?
its 4 ga at the connector even if you strip some of the wire it will only fit 4ga rubber jacket. I run 1/0 as close to the amp and then used a high quality dist. block. The 1500 draws about 180 amps when your beating on it at 1ohm. thats with around 75% efficiency.
Juan Rodriguez
Chief Technology Officer
D'Amore Engineering
T15KW Support Engineer
System.
KVT512 Kenwood Fold Out Monitor
Epic-160 Audio control Indash epicenter
(1)T1500-1BD with T2000.1 Transformer 1700 watts at 2 ohms
(2) T600-2 with T800-2 Transformers 320/ch at 4 ohms
(2) QSD216 Q series MB Quart 6.5 inch components
(3) P3D212 Rockford P3 12inch Subs
(1) Very Loud Altima Coupe!
Just use a reducer if you want to run 1/0 guage to it.
Alpine INA-W900
Rockford Fosgate Punch 200ix
Rockford Fosgate power T1500-1
Sundown SA-10 x2
Focal 6x8's front
Rockford Fosgate Power T1682 rear
Rockford Fosgate and Stinger Wiring
Powermaster D3400, S680
