Enclosure Designing: Tutorial
Hey guys,
I don't see that many threads in here about help with designing enclosures, but it is a fairly common topic for posts. I also get quite a number of PM's about designing enclosures, which I don't mind doing them...but designing your own enclosure by hand is a lot more satisfying (atleast to me).
So I'm going to start this thread to guide through how to design yourself a slot-port enclosure without using any software and for completely free (you'll only have to download 'Google Sketch-Up'...which is free)
Anyone with a highschool education and average skills with computers will be able to do this with a fair amount of ease.
You'll need these things open on your computer:
-RE's Enclosure Designer
-Google Sketch-Up
-Your computer's calculator
-Your computer's 'Notepad' feature
(This tutorial is assuming a standard slot-port that is on one side of the enclosure, firing forwards but you can easily adjust these steps to accomodate a side-firing port along with pretty much any rectangular port setup)
First:
-Go to RE's enclosure designer (this will give you a rough idea of what to draw in sketch-up)
-Type in your dimensions (W, H, D) and start adjusting your port width and length to get a good balance of airspace and port area, with the tuning youre looking for
-I like to have this design be a bit larger in airspace and also tuned a bit lower than what you're looking for, because once the sub is accounted for and any 45's in the corners and supports you may want, it will help account for them
Now you will need to go to your Google Sketch-Up window, using a blank page, to begin drawing up your enclosure
The upcoming posts will be a step-by-step guide on what to do to draw up your enclosure and how to do calculations for tuning with nothing more than a calculator...enjoy :)
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Let's get started..you will most likely have to click on the image to read the text since this forum downsizes them..
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Team Tupperware
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Team Tupperware
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Team Tupperware
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Team Tupperware
Posted Image
Posted Image
Posted Image
Posted Image
Team Tupperware
Now that you have the port's length written down along with the cubic inches of net airspace (that you should copy so you can easily paste it later, it comes in very handy rather than typing it...because it should be a moderately large number) you will just simply need to multiply your ports width x height to get your port area.
With all three pieces of info mentioned above you can start your calc's for the final tuning of your enclosure.
Start by:
-Square-root of the port area
-Multiply this by .823
-Add the length of the port
-Multiply this by the cubic inches of net airspace (which you can just hit ctrl + V to paste it to your calculator for quicker calcs)
Now copy the number you have after these steps
Next step:
-184000000 x port area
-Devide this by the number you came up with in the last step (just hit ctrl+V to paste it for faster calcs)
-Square root this number
-Multiply this number by .159
And you should now have the tuning for your enclosure :)
PS: If this tuning isn't exactly perfect you can go back and tweak your design...
Some rules of thumb:
-The longer the port, the lower the tuning
-The larger the port area, the higher the tuning
-The larger the airspace, the lower the tuning
So, youre going to have to compensate for having a large port area by making it longer, which will take up more space...something also to consider
Any Q's or things/steps that arent clear...just ask
Team Tupperware
I felt dumb when i downloaded google sketch up. I couldnt figure out how to make anything. I use solidworks and inventor modeling programs for school all the time. but somethin about how easy sketch up is, i cant seem to get it down. I even watched the youtube tutorials.haha
Yea it's actually extremely easy once you deal with it enough
Team Tupperware
the way you measure the port length is too complicated and there are easier ways. like:
Posted Image
Draw a line with your ruler through the center of your port, length wise and width wise, then measure from the port exit to where the lines intersect, and from there to the end of the port.
Other than that it's a good tutorial. But you didnt finish the box lol
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
