how do u stop the sound the back glass of an suv makes???? like a blazer could u just put sound deading material aroung the inside of the glass?
Edited by GORILLAslap
starting fresh, chrysler 300.. no subs amp nothin
I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click!
I use window blocks but it doesn't stop vibrations. I would say you could mod it BP glass
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
i dont want to stop the vibration just the high pitch noise
some weather stripping around the edges should work
R.I.P!
(Nov-29-2009)
92 explorer
current build
weather stripping would be better it will seal alot better as its foam and not a hard carpet type material
R.I.P!
(Nov-29-2009)
92 explorer
current build
^^But wouldnt that make the window not sealed around the edges?
yea my bad just throwing ideas out lol but yea weather stripping does sound like a plan
