Im looking at gettin more 0 gauge wire and was looking into stinger. Its says the wire is "tinned". Is that better or worse than using wire that is just copper?
worse. but it can be used it just depend how much current you are looking to send
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
id use regular copper wire for that much power. why go all out on amps but skimp on wire?
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Tinned just means the copper is coated which is perfectly fine.
Troy is refering to CCA wire ( copper clad aluminum.)<<< not sure if I spelled it right.
CCA wire can't carry a lot of current.
Edited by banginAltima
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
you should look into coppercableman cable on ebay, great stuff, and is very flexible :)
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
ok, wat does the coating help on? oxidation? is that wat happens to copper.
ive got wire from ebay before, it was superfat wire, says its all copper and 4100 or 4400 strand count i think
yea i guess its not the same thing is it. sorry
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Yes, Coating is to protect the copper.
Knukonceptz on ebay is the best bang for the buck wire.
I do box designs.
  • Who's Online   0 Members, 0 Anonymous, 558 Guests (See full list)
