I wanna add a rear battery to my setup how would i wire it to fit into my system
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
Words to live by.
what exactly do you mean? are you asking about how to make it live or what?
can you be alil more specific, i wanna help, but idk what your saying or trying to say.
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Would i just run 0/1 from the battery in the front to the battery in the rear or would i run some 0/1 from the pos alt to the battery in the back. And then would i just hook the amp to the batter in the back using 4 guage and then just ground the rear battery and amp to the same ground in the back.
Words to live by.
  • 1 month later...
Run wire from positive in front to the positive to the batt in the back. Ground the battery in the back to the chassis. From there ground the amp and run the power to the trunk battery.
so run + from front batt to back batt .. ground the - on the back batt to the chassi and ground the amp and then run power from the back batt to the amp? like that right? .. :D
1 12" T3 Audio TSS
saz 3000d
sax 125.2
yea, its better to use 1 solid groundpoint for everything. Make sure you fuse within 12 inches of the 2nd battery alrite.
Team PSI
Team Shock Industries
Team XS Power
Vertex Audio
Knukonceptz
best to fuse after 1st batt and before 2nd batt. and before the amp too if you want
wow thats alot of fusing .. so i need like 2/3 fues block? .
1 12" T3 Audio TSS
saz 3000d
sax 125.2
yep, its always good before the amp, but if it already has fusing then I wouldnt worry to much.
Team PSI
Team XS Power
Vertex Audio
Knukonceptz
  • Who's Online   0 Members, 0 Anonymous, 786 Guests (See full list)
