IH8PunkRok Posted March 18, 2009 Report Share Posted March 18, 2009 so some amps are 2 ohm stable and become unstable at 1 ohm (or .5 or whatever) wut exactly is becoming unstable? im just kinda curious and cant quite figure out wut is failing because of low resistance -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
raytard Posted March 18, 2009 Report Share Posted March 18, 2009 too low of a resistance, too much current flows through, too much heat is created, amp overheats and fails most have a way of sensing too low an impedance and tripping protect before they overheat others just wait until they overheat (like a higher end MA audio amp, like the hk4000 ..most times it will run fine at a low impedance until it gets hot and then shut off) Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
IH8PunkRok Posted March 18, 2009 Author Report Share Posted March 18, 2009 so when they overheat is there physical disconnections which kills the electricity flow? basically its just melting shit? -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
Audioguy564 Posted March 18, 2009 Report Share Posted March 18, 2009 When designing an amplifier one of the questions is at what impedance will it be stable. when the amp is stable at low impedance the rails are typically lower so the power supply is built for that application. The power supply is usually what makes the amp stable as it has to be over built to handle the current draw and increase dissipation of those low impedance. Juan Rodriguez Chief Technology Officer D'Amore Engineering T15KW Support Engineer System. KVT512 Kenwood Fold Out Monitor Epic-160 Audio control Indash epicenter (1)T1500-1BD with T2000.1 Transformer 1700 watts at 2 ohms (2) T600-2 with T800-2 Transformers 320/ch at 4 ohms (2) QSD216 Q series MB Quart 6.5 inch components (3) P3D212 Rockford P3 12inch Subs (1) Very Loud Altima Coupe! Link to comment Share on other sites More sharing options...
raytard Posted March 18, 2009 Report Share Posted March 18, 2009 there is a little sensor on the board that determines the temperature and causes the amp to shut down, you'r computer has one as well hooked up to the cpu and probably some other parts if its a newer computer some reaaaallly old school amps had a fuse type one that would melt and kill the connection, most new ones have a thermometer of sorts that detects temperature and cuts the amp out at a certain temp. its basically to keep the amp from frying board traces or fets from overheating, its much better to shut off and save itself. Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
