How Do I Get To My Alt? Please Help!
i have a 2003 ford taurus with the 3.0 duratech engine. my alt is on the passengers side of the engine, in the back close to the firewall, down at the bottom. how the f**k do i get to it so i can do my big 3? ive tried from the top, the bottom, and thru the fender well. no luck. PLEASE HELP!!!!! if anyone has done this or seen it done please let me know how you did it. thanks guys
2001 chevy blazer xtreme
my blazer xtreme build
On top of all that, my little sister is marrying a real fuckin winner tomorrow
I've gotten that much wood just viewing this thread. :blush:
hit up a taurus website. if you still cant figure it out by the time i get off work, ill ask my ford mechanic :D
ive searched the web and havnt found anything. its really being a pain in my ass. im tempted to go trade in my car!!! lol maybe not, but this does suck!!!
Sounds like my PT! :D
Most likely from underneath the car, might be a 'splash shield' to remove, and also might need to remove the front wheel.
no, i tried that. theres too much crap in the way
if i remember right, the easiest way is to unbolt one of the motor mounts
it has a stud that goes down through the subframe
and i think its a 19mm
or a 21mm
then u can use a jack and a block of wood
and jack the motor up some
there is a splash shield on the taurus
the inner fender
take it out
gives alot more access to the alt
there. thats what he had to say in the im lol
Guest Just_Rob
Seriously, that car is one of 3 that I refused to do installs on because of where that alternator is... For someone that is good with installs, mechanicing etc, and someone with a lift, all the proper tools and patience it's 3 hours to R&R that alternator.. Without all that, 4,5, even 6 hours.. It is BURIED in there... Be VERY careful with the output stud on the factory 4G alternator, they are easy to break and you will have to cut the surrounding plastic of the B+ post to get a bigger terminal on them.. To even get to the alt to do the big 3 is a PITA!!!
  • Who's Online   0 Members, 0 Anonymous, 1585 Guests (See full list)
