Kenwood built the KAC-9103D amplifier from the ground up to power your subs with authority. Its rugged cast-aluminum chassis houses an efficient mono power amp that'll punch out up to 900 watts RMS without putting a strain on your car's electrical system.
A built-in low-pass filter adjusts amplifier output so you'll get the best sound possible from your subwoofer/box combo, while the subsonic filter eliminates inaudible, ultra-low bass that can hamper performance. You can dial in up to 18 dB of bass boost if you want to fatten up the sound.
The top-mounted controls allow you to tweak the sound easily, and convenient front-side connections make setup a snap. Speaker- and preamp-level inputs, plus preamp outputs, provide flexibility in system design and hookup.
Details:
mono subwoofer amplifier
500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
1-ohm stable (no power ratings available)
CEA-2006 compliant
variable low-pass filter (50-200 Hz at 24 dB per octave)
bass boost (0-18 dB at 40 Hz )
subsonic filter (15/25 Hz, 18 dB/octave )
Class D design
speaker- and preamp-level inputs
preamp outputs
fuse rating: 30A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
14-7/8"W x 2-9/16"H x 11-1/2"D
this amp is like brand new i will do 150 shipped
any references?
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
shipped to 76018?
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
This topic is now closed to further replies.
