t-roy Posted March 22, 2009 Report Posted March 22, 2009 a powerbss 4 channel or a tma audio 4 channel please help getting ready to order tonight. thanks
bangin_explorer Posted March 22, 2009 Report Posted March 22, 2009 flip a coin?? or maybe give model #'s? Edit... also speakers running off them? i mean come on, info plz. thank you. ....................................................... ROE Ref's- Pornstar, Peas247, Speedcult, 98Tahoe, 2k1 sdime, 20blackls00, acidboy, t00sh0rt KICKERASSMAN, TheDukey42, RapidFire89, bass-aholic, xhilr8n , GavRiley2007, Jalat, checkmate kstms, kingscratchie, F3RR3T, Audiobahnfreak, + more... SMD Ref's- Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998, Applejack, jonathancullen89, Audioman21, Derrick824, 96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC, mbdblue, j_black10, tre4chevyryda, zfrerichs... CAC Ref's- forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak, iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie... THAT IS TRUE SUB PORN...got some sexy movement and a squirter Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move.
t-roy Posted March 22, 2009 Author Report Posted March 22, 2009 the power bass is the ASA-400.4 the tma is 4 ohm Power : 50W x 4 • 2 ohm Power : 100W x 4 • 4 ohm Mono Power : 200W x 2 • Peak Power : 800W • Total Harmonic Distortion : <0.05% • Frequency Response : 20Hz - 22,000Hz • S/N Ratio : >94 dB/W/M • Damping Factor : >150 • Input Sensitivity : 0.5 - 4.0 volts • Crossover Slope : 12 dB • High-Pass Crossover Freq : 40Hz - 250Hz • Low-Pass Crossover Freq : 40Hz - 250Hz • Variable Subwoofer EQ : 0/+18 dB • Subwoofer EQ Frequency : 40Hz • Dimensions : 10.2" x 9.3" x 1.9" • Dimensions : 260mm x 238mm x 48mm the tma isT2-320.4 Description: Four-Channel Full-Range Amplifier Linear Bi-Polar Design PWM switching type, unregulated Inputs: Two Stereo Pairs (RCA Low-Level or multi-pin High-Level) with 2/4 Channel Input Switch Input Sensitivity : Low-Level 200mV - 4V High-Level 2V - 10V Amplifier Topology : Linear, Complementary Bi-Polar (Class Rated Power 14.5 V: 60W x 4 @ 4 ohm 80W x 4 @ 2 ohm Rated Power 14.5 V (Bridged): 160W x 2 @ 4 ohm Preamp Output : Pass-through type with unity gain Frequency Response: 10 Hz - 25 kHz +/- 0.5 dB Bandwidth: 15.40" x 9.60" x 2.15" (391 mm x 244 mm x 55 mm) Dimensions (L x W x H): 15.40" x 9.60" x 2.15" (391 mm x 244 mm x 55 mm) the speaker are 6.5 in the front phoniex gold and also phon. gold 6x9 in the back dech
