slugdub Posted March 24, 2009 Report Posted March 24, 2009 So if I use a quality rockford 100% copper 8 gauge ground (only a couple of feet) with a 4 gauge CCA (about 17' feet or so) to the battery, would there be any potential problems? Is it ok for at least a day or two of testing? I'm only probably pulling 50-60 amps (guessing) with an 80 amp AGU on the positive terminal.
tacomabanga1986 Posted March 24, 2009 Report Posted March 24, 2009 i had mine in my geo like that befor and no problems with it, i got rockford 4awg in there now, works fine here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
slugdub Posted March 24, 2009 Author Report Posted March 24, 2009 i had mine in my geo like that befor and no problems with it, i got rockford 4awg in there now, works fine Ok, thanks. I figured I was ok, mostly due to the short length of ground vs long + wire. I'm still pissed I ordered tinned wire, oh well.
fritosaregood Posted March 25, 2009 Report Posted March 25, 2009 Ok, thanks. I figured I was ok, mostly due to the short length of ground vs long + wire.I'm still pissed I ordered tinned wire, oh well. Tinned wire is different than cca wire seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
slugdub Posted March 25, 2009 Author Report Posted March 25, 2009 Tinned wire is different than cca wire lol, well which is better? I just got my CCA package now. Its fatty, but its definately not "copper clad." More like 'some copper mixed in.'
fritosaregood Posted March 25, 2009 Report Posted March 25, 2009 cca is mostly aluminum tinned is copper wire with a coating to resist oxidation tinned is better seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
creyc Posted March 25, 2009 Report Posted March 25, 2009 Silver tinned copper wire is yummy stuff. That's like kicker/rockford wire. It's heavy copper wire with a shiny silver look. Regular welding cable is usually solid copper, orange in color. Cheap, 'does the job, usually really good oil/fuel resistant insulation on it. Great for under-hood applications. Blends in well. Copper Clad Aluminum is a WHOLE different animal. You can tell just by picking up the package, it weighs less than half as much for the same linear quantity of wire. Very cheap, less conductive than the above two, often found on ebay. I wouldn't use this stuff for high powered systems. I prefer not to use it at all, but on a budget it has its uses. 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck
