cut 8 10" holes in a big box haha j/p
get your max measurements look around on this site get some
ideas for a design you like then ask someone or get somebody to make
you a 3D design of it.
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
thanks, ill do that., i have another question, my wife has 4 Hifonics Brutus 12's in a sealed box with 1 Hifonics brutus 2608 amp. She has two Kole 5-farad digital caps for each amp. how do i wire them to each amp?
Current Setup:
Sony CDX-7401UI
2- 12" Alpine TypeR DVC2ohm Subs
Custom ported box
4-American Bass 6.5in SQ-6B Mids
4-Pioneer TS-T15 Tweeters
2-Crunch P1500.1 Mono Amps
2-runs 1/0 GA KnuKonceptz
KnuKonceptz RCA's
1-Stinger SPV44 Battery
Coming soon:
250 Amp Alt
Custom Door Panels
Second Skin Sound Deadner
All in my 1986 Monte Carlo SS!!!
woah there padre, 1 thing at a time.
Are you sure you really want to use them caps? I've learned here that their application is rarely necessary and usually only for eeking that last bit of stable current for like a competition rig.
I'd say sell the caps and look at this:
Someone can correct me if I'm wrong, but if you have 2 ohm DVC's then it should present a 1 ohm load (which the amp is stable at) otherwise its 2.
Thanks Dub, but id like to add that, i thought (me being a noobie here), caps were made for storing current like when your headlights dim, which her car does like crazy and thats why we bought the caps. So what can I do to correct the problem. Her system consists of a Hifonics Zeus 14408 4 ch amp which runs a set of MB Quart 6 1/2 coms and a pair of MB quart 6x9's, an AudioControl Epicenter, 4 Hifonics Brutus 12's, a Hifonics Brutus 2608D amp and a Pioneer Premier deck which has 4 volts, all 2 ga wiring, and 10 gauge sub and speaker wiring.
Current Setup:
Sony CDX-7401UI
Custom ported box
KnuKonceptz RCA's
Coming soon:
250 Amp Alt
Custom Door Panels
have you upgraded the battery and "big 3" (earths)?
doing this usually get rid of most headlight dimming, also upgrading the amps earths to a bigger guage and making sure they have good contact with the body helps a bit,
as for the caps, since youve already got them you may as well put them in but im not quite sure how to do that. doing all the other stuff first is a good idea though
^^^ clicky pics for build logs ^^^
  • Who's Online   1 Member, 0 Anonymous, 1311 Guests (See full list)
