So does the kit bolt on in place of the factory springs or in addition too? Also, will this damage anything in regards to my TBSS being AWD? I also have a compressor on my truck, it hols up to 84 lbs. I believe will this help or can it even be used. Also, is this the only option? Is it the best option?
Does your trailblazer have coil springs or leafs in the back these are bolt on kits very easy to do. They dont replace the springs if they are coils they go right inside of the coil springs if they are leafs they go right on top of them. your comp should be fine then they come with a little manual fill knob on them you just have to choose where you want them to go
I am not sure if I have coils or springs I will go look tomorrow. Do I need to make any mods to my factory compressor? Which kit do I need to buy the $84 or the $49 one.
Rockford Fosgate
DC Power Inc
XS
Autometer
Pioneer
$84 dollar one what kind of compressor is it and where is it located you only fill these when there is weight in the back you dont have to keep refilling them or anything like that. Is it a compressor for filling like say a bike tire or what.
It comes on the TBSS. It has a output for filling bike tires but it also equalizes the tire presure of the tires from what the owners manual says. The system is going to be permanent so it will need to be filled at all times. It i cant use the factory compressor do I need to buy one in addition to the 84 kit? Is there anything else I need besides the kit?
Rockford Fosgate
DC Power Inc
XS
Autometer
Pioneer
nope your compressor will work just fine
with the TBSS being awd can I bag the whole truck?
Rockford Fosgate
DC Power Inc
XS
Autometer
Pioneer
Probably not bag it as in bagging it to lay out on big rims this kit is for weight control not looks just function also the little air nozzle the guy was filling in the video can be mounted anywhere you want to mount it
you gots coils in the rear so you need to get you some "coil rite" air bag helpers Firestone part# 4106ce or the Air Lift part# is 60779
suspension connection has Air Lifts on sale for $67.95 http://www.suspensionconnection.com/cgi-bi...ir-springs.html
Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW=
I was told that 2wd vehicles can only be lowered or bagged. Is this true? My TBSS is awd do I have any options in terms of bagging the whole truck?
Rockford Fosgate
DC Power Inc
XS
Autometer
Pioneer
Idk if this is right or not , but aren't there shocks you can get that have schrader valves on them so you can air them up and use them as sorta-helper springs?
Too many projects, too little time...
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
