also, depending on the situation, power wire does or doesnt stop headlight dimming... Your electrical is also a big factor, as well as whether or not u did the Big 3...
But in your situation yes the 4 gauge should make a very noticeable difference in your car...
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
It's also possible that your ground point sucks. Try to find a spot on the chassis to ground to if the noise is bad.
EDIT:spelling
Ok, I'm going to do that tonight. Reading back in this site is helpful too, lots of info about good grounding and keeping those RCA seperated too. I should be ok.
Now if I can just figure out how to get the damn brass terminal i bought to tighten up on my battery, I'll be set.
