Next build amps
36 members have voted
  1. 1. Which amps should I go with for the next build 24k?
    • (6) Memphis MCD4KWs as planned
      15
    • (3) Stetsom 7kd (12V system so no 10k)
      18
    • Other... please list below
      3
I know that the 4k's are crazy on 16v but on 12v I can't say. I know if you can supply the electrical you're looking at least 6000w per 7k2d assuming you can keep at least at 12.8v. Keep voltage higher even more power.
get Z2lvs for around $1200
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
get AQ 3500D for 699 shipped.
they do all 3500 watts and if you can step it up to 16 volts they do 4K.
or do an 18 volt system and it will put out 6500 watts!
not sure about the 18 volt but
i have seen these things on 16 volts though and it does 4K and a lil more. they are very picky with clipping so you would have to be careful and set it up right.
plus they are very hard to blow. i've had my 2200D all the way to 9.7 volts and it worked fine.
they are fairly efficient as well.
as far as spl amps, i haven't found an amp that beats Audioque for the money.
Z2LV > all
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
i voted for the 7kd's cause they will be plenty beastly if you're on 12-14ish but when you upgrade again you could just convert to a 16 voth system and have a ton more power so that my logic
justin smith
1996 mercury grand marquis
20'' bentchi b7 lexani n3000 245/35/20
cactus 5kw at 1ohm dcr(beast)
2 18'' btl's in a 14.15^ft wall tuned to 35hz with 210'' of port
kicker zx650.4
componets in still the works
200amp motorcraft alt
xs power d3100 (beast)
kenwood ddx512 h.u.
you mean my EX? the one I dumped? just remember every time you kiss her that i used to cum in her mouth
and BTW your girl just called me....
pure pwnage
you have to remember that if you are running 16 volt batterys you will actually be running 18+ volts with the alternator.
not sure if the stetsom will handle 18 volts, it might. i'm not that familiar with stetsom. only know what i have heard about them.
Edited by brewer_brewer
