would i have any problems with it on a basically stock elctrical system
not really considering it only has 80 amps of fuse in it.
do the big three, and adding a small batt should take care of voltage probs
that was the basically part. i have the big three done and a larger battery up front so i should be fine?
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
Yeah you'll be good. Now go get one!
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
i plan on it verrrrrry soon .i get paid next monday i will order it from somewhere
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
i have a 1608D 25th anniversary edition on stock
electrical and some shitty battery up front and when
driving volts will drop to 12v min
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
My 1208D is freezer cold. Got it tested with some expensive equipment and it turn out to be 890Watts @1 ohm 12 volts with 10% THD. Can wait to know what these beast turns out to be @ 14.4
