i need about 6-10 feet of 1/0 wire for a big three upgrade. I know i could just buy from about 30 varous companies but i figured i may could get it cheaper here and maybe help out a fellow member. Anyone wanna hook me up? also looking for 1/0 ring terminals and a 1/0 anl fuse holder.
Edited by troy
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
i know some one has some
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Very little left from my build look i did sum research the best wire is welding cable 1/0 i used 0 but go to ur local welding shop where i was it was 2.00 a ft. It's better than the audi stuff little better current no restriction. And for the terminals ur local hardware store there are a few threads on youtube about soldering the terminals. Hope that helps out.
i can solder them but the largest terminals i can find around here are 1/4 inch terminals form autozone. Idk if they are large enough
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
to fit 1/0???
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
