Hey Guys, So I got a new car, it's a 99 mercury mountainer V6. I have a soundstream 12 inch sub and a soundstream amp to power it. I plan on a ported box and some 1/0 guage wire. Nothing to fancy just a simple setup. My questions are:
Is there a rca jack in the back of the factory radio foir my rca's?
I will be running no more than 1500 watts rms, so should I do some major upgrades to my electrical system?
Any body with the same car that may have some tips for me about removing the factory radio..... ect?
Thanks guys
If i was unclear just let me know, I would be happy to explain/ ask more haha
Scott
1995 Jeep Yj
Rubicon Express Lift
BFG Tires
Warn 9000lbs Winch
KC offroad lights
1999 Mercury Mountaineer
(need to install)
12in Sub
Soundstream Amp
1/0 wire
4 Channle Amp
Replace the factory head unit
Factory radios usually don't come with RCA jacks so you'll have to buy an adapter. You'll probably need to replace your battery under the hood and maybe a smaller one in the back, and the big 3 of course for 1500 watts, depending on your eletrical.
2000 Jeep Cherokee
-DC Audio
-Memphis
-Audioque
-SecondSkin
-Pioneer
-KnuKonceptz
Most factory radios don't have RCA outputs, most likely you will need to use the high level input if it came with your amp.
Thanks guys for the help
Ya i think I know what you guys are talking about, know where to get one for decent price?
1995 Jeep Yj
BFG Tires
Warn 9000lbs Winch
KC offroad lights
(need to install)
12in Sub
Soundstream Amp
1/0 wire
4 Channle Amp
anyone have more information on this high level imput thing
1995 Jeep Yj
BFG Tires
Warn 9000lbs Winch
KC offroad lights
(need to install)
12in Sub
Soundstream Amp
1/0 wire
4 Channle Amp
walmart sells them for cheap. if walmarts not your thing darvex and likeeveryother audio website has them.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
thanks guys
Is a high level input the same thing as a line output?
I am trying to make my factory radio have rca jacks for my amp. What do I need?
1995 Jeep Yj
BFG Tires
Warn 9000lbs Winch
KC offroad lights
(need to install)
12in Sub
Soundstream Amp
1/0 wire
4 Channle Amp
thanks guys
No don't worry bout "high level inputs" some amps have them some don't just get a line output converter from any place and splice it into your rear left speaker line then run the RCA's from it to your amp, don't forget to run the remote turn-on lead.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Dont worry I wont forget the remote turn on line haha, thanks for the info man, But does the line output thing have to be spliced into the rear left speaker wire or can it go into any of them?
1995 Jeep Yj
BFG Tires
Warn 9000lbs Winch
KC offroad lights
(need to install)
12in Sub
Soundstream Amp
1/0 wire
4 Channle Amp
