Bass Boost And Why Its So Bad?
bennett15
Okay i know that using bass boost causes clipping and on and on
but why do manufactures still put it in there amps? i know on my
amp if i turn bass boost completely off the sub does not play? so i need
at leat some of a bass boost. Also it sounds like i have no bass if its not turned up
gain is set correct with dmm but there is substantially less bass output.
Just want some one to clarify this.
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
ill do my best to explain.... u can use bass boost to some extent, but without seeing the signal on an oscope or utilizing a clippin light, ul never know when uve made the signal more dirty and clipped
heres an example: frayser boy - me being me
Posted Image
peak is 11db at 50hz
Posted Image
6db bass boost
Posted Image
12db bass boost
Posted Image
18db bass boost
Posted Image
24db bass boost
Posted Image
u can see that the song utilized up to 12db bass boost before clipping.... so itd be fine to use boost, but no song is the same so there is no set boost point thats safe
as a rule of thumb i never use more the 6db boost, ever... if the subs not hitting loud enough, something else isnt right, boost isnt meant to help that... and its usually centered at 45hz, which if the songs peak isnt around that, ur not turnin it up as much too
try turnin the sub volume/level up on the headunit
for example alpines go from 0-15, full voltage is only present at 15 to get 2/4v
my jvc goes from 0-12 and it to needs to be at 12 to get ~5v
okay my deck has a sub pre out but its
brown in color and does not have left or tight just a single
pre out? what do i need a Y spliter thing?
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
yes i realize that but it only has one pre out while my rca's have a left
and right pre out
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
if your running a mon amp it only requires one side being that bass isnot stereo
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
and right pre out
thats what u need, the male goes to ur headunit preout, and ur rcas (l&r) go to amp l&r
not necessarily, if the preout for the sub has left and right u might need both to get full voltage
okay because on my h/u i have the subwoofer mode on but when i adjust the volume of it it doesnt get any louder
so im guessing thats b/c im using the rear pre outs instead of the sub pre out?
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
  • Who's Online   0 Members, 0 Anonymous, 1404 Guests (See full list)
