i dont think u can if they are 4ohm, if they are 2ohm then just wire each sub in series to make them all 4ohms then run all 4 subs in parallel to get a 1 ohm load.
1999 Eclipse N/T
12'' Fi BTL
Gp3000d
PM D3100
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
try doing some research hoss...
but ill make it easy on you
with 4 dual 4 ohm subs you cant make a 1 ohm load. you can make a 2 ohm load and get an amp that peaks at 2 ohm and run it there OR you can get 2 1 ohm stable amps and parallel 2 of the subs per amp to a 1 ohm load
OR
Edited by Chode69
NoFearX18 said:
trainman0978 said:
MAn i keep telling you, they can't be wired to 1 ohm.
and that amp will barly do anything for those subs, you'll be under powering them, get the colossus
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
Why cant i wire it like this?
because those are DUAL 2 OHM SUBS
NoFearX18 said:
trainman0978 said:
Guest GPMACHINE
This is kinda on topic here... If i "strap" two Kx1200.1 amps together do i get 1200x2 at 1ohm or 1200x2 at 2ohms?
  • Who's Online   0 Members, 0 Anonymous, 2756 Guests (See full list)
