This is kinda on topic here... If i "strap" two Kx1200.1 amps together do i get 1200x2 at 1ohm or 1200x2 at 2ohms?
Matters on what ohm load the speakers are wired to. If your subs are wired to 2 ohms then you will have 2400 x1 at 2 ohms. but each amp will be 1200 @ 1.
Guest GPMACHINE
So... If i wire my subs at 1ohm with 2 KX1200.1 "strapped" together what will my final watts/ohms be per amp? Will i be pushing each amp down to .5 ohms? Do you understand where I'm coming from?
I trying to figure out a better way of asking this... What happens when you strap amps together? Do you add everything by the number of amps?
For instance:
1 KX1200.1 = 1200@1ohm
2 KX1200.1 = 2400@1ohm or 2400@2ohm
3 KX1200.1 = 3600@1ohm or 3600@3ohm or 3600@4ohm
Too answer my own questions, I think i should learn more about ohms, LOL! - Bob
  • Who's Online   0 Members, 0 Anonymous, 8227 Guests (See full list)
