you shoul atlest do the big three. the Fi subs are no joke. any one of about 4563 things can cause them to blow. they are pretty picky. so iif this is your first system i recomend starting a lil smaller and learn what works ad what doesnt. then upgrade
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
if your going to run fi it has to be done right.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
should i get this one? and what size fuse? knu
1 fi bl 15 with 1200w going to it, stock electrical, new battery.
Ill be using this amp Merlin link
the KNU CCA wire is not a bad choice for under 1500 or so rms, so it would be a good choice in your range.
fuse will depend. im running a similar setup currently and i use a 150amp inline fuse. i would reccomend one in the same area. Fuse size is going to be dependant on how much power you are drawing in. the power you are drawing in depends on your amplifier's spec's. can you give us some more info?
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
good wire , more juice to the amp, more power to the subs , don't cheap your subs out of power , you will be happier in the end if you save and buy the right wire, don't jump the gun, you'll be wanting to sell the cheap kit in a week if you buy it and want the right one, save your self the hassel. this is from my own experience. so i not being a smart !@# just trying to help.
i personally run the same kit just modded a lil.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
its not at all but with the FI i would upgrade atleast the big three
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Lol whats Fi sub have to do with electrical or big 3? Or gauge... Only thing that matters is your amp and its draw.. That amp 3x 30amps fuses = 90amp draw.. Get a 2ga amp kit http://cgi.ebay.com/POWER-ACOUSTIK-2-GAUGE...%3A1%7C294%3A50
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
  • Who's Online   0 Members, 1 Anonymous, 2613 Guests (See full list)
