any of you guys knows if it is possible to get a aftermarket amp on a premium sound system from volvo? I want to stick with the stock headunit / console.
need some RCA outputs in there! not a big fan of the highinputs. lots of disorders / complications.
need some help!
thanks in advance!
yeah i heard there is running like a 100 watts on each speakercable. thats like 20 volts. am i right? there aren't a lot of devices that work with such high voltages.
really need your help guys!
SplPhreak : Thanks for confirming my thoughts :P
i really need some slap in my new volvo for sure.
you could use a 360.2
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
don't think that'll do. its a surround sound system. noise will be my biggest enemy in this case. (correct me if i'm wrong)
altough thanks for advise!
the 360.2 is your answer,all it needs is a signal from your source.as far as surround goes you may need 2 360.2's but will be costly and a pita,(if it can be done)..
as far as sound goes,the 360.2 i used in my car was very quite and presented very little if any unwanted noise....good luck
07 mote carlo..
deh-p800prs hu-cdt gold 6.5's-cdt 6x9 2 ways-mcintosh mc431m(mids/highs)
bxi2608,2 10w7's in 4rth order(designed by pete k)ported into cabin via armrest cutout
dc power 260 amp alt-missing link module (15.4v)kicker 1/0 kit deka intimidator under hood
metered 141.0 @ 32hz windows down @ kick,termlab
damn more expensive solution then i hoped for :) but the 360 will make things more perfect for me...
i think a high input to low output (rca) adapter is a no?
many thanks to you guys!
You could also use a JL Audio clean sweep. It's not as expensive as a 360. Here's what I'm talking about.
http://cgi.ebay.com/JL-Audio-Clean-Sweep-C...%3A1%7C294%3A50
Not a bad price either.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
  • Who's Online   0 Members, 0 Anonymous, 3119 Guests (See full list)
