What size enclosure should I use? I found this http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=2%5F0%2Dmsw%2D112 and I think it would be the right size for my trunk and the sub. Also what amp should I use? I found this Hifonics brutus amp http://www.sonicelectronix.com/item_12210_Hifonics+BXi+1208D.html would it power it well?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
anyone?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
i run a 2 cu. ft tune to 34 HZ with 13 square inches of port per cu. ft.
off of a AQ 1200 D.
did a legal 144.8 sealed up in the kick.
off of a AQ 1200 D.
don't buy a prefab. they are usually tuned to 40 HZ and higher.
that hifonics will only do 1000 watts. get the AQ for 249 shipped and it will do 1200 all day.
what size box should I make?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Im a little short on trunk space but I will go and measure right now. How big is your box?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
ok got some measurements
W D H
38 19 17 ( biggest possible)
36 38 17 (whole trunk my trunk has weird curves)
42.5 19 (opening)
And I want it ported.... Any suggestions
Edited by marquettefan247
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
do whatever dimensions you have to to get 2-2.5 cu. ft. with out the port
and then tune the port to 34 HZ with 12-16 square inches of port per cu. ft.
no clue what you you said. I just need someone to give me the dimensions. I donot know ow to do all the sub prgrams
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
W D H
42.5 19 (opening)
That comes out to 5.8865 cubes. Plenty of room.
  • Who's Online   0 Members, 0 Anonymous, 3073 Guests (See full list)
