uhoh_45 Posted April 7, 2009 Report Posted April 7, 2009 so i cut one of my sub holes out and turned out its .25" to big baffles 1.5" to thick i figure if i put a .5" baffle ontop of that cut the hole out normal and mount it to the box i could resin the gap between the two and fill it in will this work? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
brewer_brewer Posted April 7, 2009 Report Posted April 7, 2009 i would think so. if you didn't have 3 feet worth of baffle i would say it might not be strong enough. lol but you do. less room in cab= it might even give you higher numbers. REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
Boon Posted April 8, 2009 Report Posted April 8, 2009 so i cut one of my sub holes out and turned out its .25" to big baffles 1.5" to thick i figure if i put a .5" baffle ontop of that cut the hole out normal and mount it to the box i could resin the gap between the two and fill it in will this work? It might just crack like crazy when you put screws in it... 10.x volts fo' life!
zfrerichs Posted April 8, 2009 Report Posted April 8, 2009 just use some more duct tape haha im just fuckin with you bro. you can do that just make sure that the screw, t nuts whatever your going to use goes into the 1.5 baffle and youll be fine Roseville, CA
