a installer at my work has a air ride kit he got from a costumer (costumer had it on his car... costumers wife hit a pot hole an somehow broke one of the bags... the rest is now the installers) he has the air lines, a tank, the compressor and the switch box.... i need to know how much some good bags are that would fit my blazer and what all id have to do to put it on.... this isnt a really sweet kit, it only has front an back controls but he'd sell me it for $100 (an we all have to start somewhere...) so i figured id ask the people thatd know best what i should do! thanks for your input!
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
slam re-7s up front re-8s out back. cups for up front and a notch and 4 link out back. and good welding skills.
do you have to do a notch? im not looking for anything too sweet like some of the peoples on here, just something so i can lay low but still be able to lift it back up, other wise id just lower it, i dont care if i can lay frame on anything(tho eventually id like too)
Build log: Click
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
going cheap you can get a two link and a panhard bar for the rear, Slam Specialties RE7's will be fine back there
front cups and Slam Specialties RE6's (RE7's if you can fit them without major modification.
You can mini notch the rear without having to cut into the cab, if not you will only get about 5" s of drop before you hit the frame. You can get a bolt on notch or a weld in, if you are not looking to spend a lot of money you won't lay frame but you can get pretty close.
if it is compressor, tank, valves and switchbox you are getting a good deal even if it is cheap equipment. KP Components might even make a bolt on kit for the rear, I think Suicide doors may as well. Look into it cause it won't lay frame but makes install a whole lot easier for a first timer.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
yea id run atleast a mini notch so u dont bottom out all the time. and i would go with atleast re7s up front if u have the 4.3 my 4.3 s10 took 130psi to lift with re-6s.
thanks for the input, where would i find these bags?
Build log: Click
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
www.suicidedoors.com
  • 1 month later...
he now changed it to $50, i think ill get it just to have
Build log: Click
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
im looking at all the stuff on suicidedoors.com and i have no idea what all id need to get, can someone help?
Build log: Click
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
  • Who's Online   1 Member, 0 Anonymous, 1642 Guests (See full list)
