So How Would I Wire This?
which amp do you want? The 10k or the 5k? If 10k, then get dual 1Ω subs.
well see, i wanted to wire them together so i have 15,000W all together. unless i can find a 14,000W or 15,000W amp. if not, then i'll just take the 10K.
1994 Ford F150 reg cab
2 HFX 12's
Audiopipe APSM-1300
here you go :D
amp
holy %*^! yes, i've seen that. but i REALLY don't want to spend $25,000 on an amp. that's why i thought it might a good idea to just run 2 amps because it'd be cheaper.
OR!!!!!!!!! i can run two Hifonics XXVSampsons. they put out 8K each and i could just have 4K to each sub. like put 2 subs to each amp.
2 HFX 12's
Audiopipe APSM-1300
You can't run the 10k and 5k together.
2 8k's is a better option for you... and the Sampson doesn't make 8k unless you give it lots of voltage.
Stetsom 7kd2 or DD Z2LV or Soundigital SD8000.1 or Stetsom 10k are all good options :)
EDIT: For the money 4 SAZ-3000D's would give you a lot of power.
Edited by Boon
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
