ok, I have a 2006 dodge magnum wagon, I have 2 12" solo x's, and I'm gonna get the box as close to 12 cubic foot as possible(gonna be ported), and I am not sure which way to face the subs to get the best numbers. right now I have one in a 6 ft box, and it is facing up to the roof, and so is the port....it sounds good, but when I face it forward it sounds like crap....shouldn't it sound better?
subs up port back
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
Uh, what? A 12" sub in a 6 cube box, holy excursion batman!
yea i just seen that. if i remember right kicker recomends 3cubes max
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
according to kickers website.....
Model:
S10X
S12X
VentedSUV (TheOneToDo)
4.91 ft3 (139L) + port displacement, Fb=45Hz
Port: 60 in2 (387cm2) area x 8.75” (22.2cm) long
Power Handling = 1500W Peak
6 ft3 (170L) + port displacement, Fb=45Hz
Port: 60 in2 (387cm2) area x 6” (15.2cm) long
Power Handling = 2000W Peak
I did the one for the 12". They say this is for the daily listening, they have one for comps also......
6 ft3 (170L) + port displacement, Fb=68Hz
Port: 250 in2 (1613cm2) area x 9” (22.9cm) long
Power Handling = 2500W Peak above 68Hz
any idea why my sub sounded like crap when I had it turned to the front?? was it because the port was facing front? Should I try 3 cubic ft for each? tks
This is somethings we do. We will take a sealed box and turn it all over the place to get our peak and to see which way the sub was facing when it got the highest numbers. Then after we know our peak we build a box with a removable port for the peak hz'z, then go back through all the setups before and get what we can get and then we would build a final box. It takes time but it's worth it in the end.
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
