ok so the battery in my truck is bad i think it is hard to start the truck so i want to get a new battery. i was thinking a yellow top because i want a system but dont want to spend 200 on a battery. what is a good all around battery for a decent price?
those are good starting batterys to?
They are good in all aspects. Starting batteries are mainly high discharge which all Kinetik (or Powermaster XS) are designed for.
Need an install? Hit me up.
[email protected]
i just looked up a kinetik and the one it said for starting is 350 bucks.
that is a good starting battery to?
powermaster. shoot "mechman" a pm.
he sells powermaster batteries and can give you a great deal. powermaster are just as good as kinetik and better than optima.
he has a section on here to.
he said to get a hc600, and thats what is for sale on that ebay page.
i use a single yellow top in my car and im noticing that my voltage can not go higher than 13.1 Volts. I've heard that yellow tops dont go much higher (voltage wise) for some odd reason, where as a kinetik or powermaster battery will go to 15+ volts if done correctly. if you want a very "strong" battery, then stick with the kinetiks or powermasters!
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
  • Who's Online   0 Members, 0 Anonymous, 648 Guests (See full list)
