SO... .Since no one in the t-line thred will answer me I decided to make my own thread.. maybe Ill get some responces lol... Im trying to make up a t-line design for a 12" DC lvl4 xl. Port forward sub forward .. that way i can seal it from the trunk and all the pressue will come into the cab.I got the specs from here:
http://www.dcsoundlab.com/specs.html
12"
Mounting Depth
7"
Mounting Hole Diameter
11"
Motor Width
8.75"
Weight
54lbs
VC Diameter
3" Flat 8 layer
Magnet Weight
50lbs
Power Handling RMS/Peak
1500/3000
Impedance
D 1 or 2ohm
Sd
494.00 cm²
Fs
38.90Hz
Qms
6.51
Qes
.31
Qts
.29
Xmax
26mm
Sensitivity
90.73
Suggested Sealed
N/A
Suggested Ported
1.75³-2.75³ ft
Using math on the first page then I should have something like this:
( 1130 / freq ) / ¼ = ¼ wave length and ( Cone Area / 2 ) = ( X )² x 3.14 = X in²
SO....
( 1130 / 38.9 ) / ¼ = 7.26ft and ( 11 / 2 ) = (5.5)² x 3.14 = 90in²
This is were i start getting confused.... I need to keep a constant 109in² ... So... if I want my box to be 16in tall externally. Then height inside would be 14.5in (using ¾ MDF). Which means the width of the port can be 6.21875in wide. 14.5 x 6.21875 = 90.171875in²
The tunnel would be 14 1/2in x 6 7/32ln x 7 1/4ft long??
Im trying to stay within measurable fractions. Figured it wouldn't hurt since we rounded down in the first place. Good enough?? Is my math correct??? Please lmk if it isn't and or what to correct. Also the (freq) is the Fs or does it need to be the desired tuning? Like if i wanted my box tuned @ 32 I need to use 32 in the equation?
If I made a T-line for a single 12" DC lvl4 XL using 3/4 mdf. Th box dimensions of L: 36 3/4in W: 24 3/4in H: 16in and the tunnel measuring 14 1/2in x 6 7/32ln x 7 1/4ft long. Taking that into accoul the guts of the box would loong along the lines of this:
Could someone check my math or w/e and lmk if Im on the right track? Thanks in advance.
-Kurk
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Everything looks good.
Unless you are limited on your box size, I would tune closer to 30hz personally.
X2 But I also love the lows.
2 Infinity Reference 1252w 12s
4.2 cubic foot box tuned to 28hz
Sub amp: 1 Profile AP1200
Speaker amp: 1 Sony Xplod XM-504z
Kenwood eXcelon KDC-X492
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
f05112e8-c6ca-4f78-9a8d-47be99303c8b_zps
Diamonds are forever, but 9's end that shit fast....
kk, so the (freg) is for the tuning? ... sweet i need to adjust it cuz I though 38.9 was to high just wasn't sure.
You really shouldn't tune below Fs of a sub in a t-line. Tuning at the Fs is the best possible t-line enclosure you can build for the sub. The Qts is .29 so even at that tuning you will be hitting the low lows with ease.
I would stick with the original plan and tune to 38.9. Assuming it's done right, you might be getting a pretty flat response from 20-ish hZ to box tuning. Cabin resonance plays a role in this too, so be aware.
Looking at your measurements, it seems a little small, but the math says it's ok. And tuning lower will yield a much longer port (10+ft). I don't know how much space you have to work with, however.
If it's done right and you maintain the port area (try to round it if possible), you'll have a very loud, very low, very clean sound.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
ok Neo, I guess u just confused me lol... 38.9 is the subs Fs I built the plans based on it. First you said I should stay with that. Then you suggest tuning it lower... I d like to have it around 32ish... would that perform well? Or would I be better off with something lower or just staying with the fs?
Sorry if that was confusing. I was saying to tune to the sub's Fs.
I was just mentioning that the port would be significantly larger for a 30hZ tune.
[email protected]
ahh ok, just excuse my noob ness.. ive only built one sub box before... but i didnt make the plans for it. Speaking of whick if i figured out all the math etc would someone be willin to auto it up for me??
It would be really tricky. We mainly use Sketch-Up for boxes. I haven't seen many use cad.
If you haven't had much experience with boxes (let alone t-lines) this might be a very difficult task. Almost a trial and error going through a LOT of wood.
Where are you located?
EDIT: n/m not near me
Edited by Neo_frog
[email protected]
i have an old ED 9kv.2 laying arround i wanna play with a tline
the fs on the 9kv is 23 so it would be
(1130/23)/4 =12.283ft (7/2)= 3.5x3.5x3.14= 38.465sqin
sorry to jump in ur thread bro
just crunchin numbers now
Team O.B.M
'97 Tahoe
Build after the new year!!!
Kenwood kdc-x794/16gig android tablet
6 sets of Crescendo ccx65s
2 18s
2 Sundown saz 4500s
2 Sundown sax 100.4
1 Mechman SMD spec 360a
4 XS d1400s
My Feed Back
http://www.stevemead...showtopic=44841
2lc49k5.jpgub
  • Who's Online   0 Members, 0 Anonymous, 2907 Guests (See full list)
