AP Zoutes Posted February 25, 2007 Report Posted February 25, 2007 just go to crutchfield and search for it that way. itll give you all the different options to choose from. w/ or w/o bose, onstar all that shit. but what you don't understand is the harness is wrong for the late model 2000 tahoe. The facotry amp turn on lead is on the secondary harness. I ordered mine from crutchfield still needed to do the splice.
sean 371 Posted February 26, 2007 Author Report Posted February 26, 2007 I just went through this today. If you look at the back of the stcok H/U there are two harnesses. One main one and one second one that is smaller. On the second one will be a pink wire. You need to splice the pink wire to the remote turn-on off your new H/U. This wire turns on the factory amp. Thanks man that's what I've been wondering. Do you know if the stock radio controls airbags, other functions? I'll go do that splice right now if it doesn't affect any thing safety-wise. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
AP Zoutes Posted February 26, 2007 Report Posted February 26, 2007 afffects nothing. the pink wire is just the turn-on lead for the factory amp.
spcdwayne Posted February 26, 2007 Report Posted February 26, 2007 maybe this will help if it's neccesary. GENERAL MOTORS P o w e r Memory (+12v Constant) Orange Ignition (+12v Switched) Yellow Ground (-) Black Illumination Gray Dimmer Brown Power Antenna Pink S p e a k e r s Right Front (+) Light Green Right Front (-) Dark Green Left Front (+) Tan Left Front (-) Gray Right Rear (+) Dark Blue Right Rear (-) Light Blue Left Rear (+) Brown Left Rear (-) Yellow
sean 371 Posted February 26, 2007 Author Report Posted February 26, 2007 Thanks a lot AP zoutes. I've been trying to avoid spending that extra 100 bucks that i DONT have, so this helps a lot. I'm gonna go hook my h/u now haha. What are all the other wires for on the smaller harness then? A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
sean 371 Posted February 27, 2007 Author Report Posted February 27, 2007 maybe this will help if it's neccesary. GENERAL MOTORS P o w e r Memory (+12v Constant) Orange Ignition (+12v Switched) Yellow Ground (-) Black Illumination Gray Dimmer Brown Power Antenna Pink S p e a k e r s Right Front (+) Light Green Right Front (-) Dark Green Left Front (+) Tan Left Front (-) Gray Right Rear (+) Dark Blue Right Rear (-) Light Blue Left Rear (+) Brown Left Rear (-) Yellow Thats for the larger harness, I'm confused about the second smaller one. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
AP Zoutes Posted February 27, 2007 Report Posted February 27, 2007 Thanks a lot AP zoutes. I've been trying to avoid spending that extra 100 bucks that i DONT have, so this helps a lot. I'm gonna go hook my h/u now haha. What are all the other wires for on the smaller harness then? I don't know. I did mine on saturday and no change to anything. I think it's the amp turn-on off course and possibly something to do with the tape player. I've had no trouble lights come on and everything else is normal.
sean 371 Posted February 27, 2007 Author Report Posted February 27, 2007 Hmm I'm just a little concerned about the airbags thing. But I think all those wires are for the door chimes coming off each door/trunk, the ignition, and lights. So I'm going to go ahead and do the splice. Saved myself 100 bucks too. Your door chimes shouldn't work now right? That's fine with me those damn things are annoying shit. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
sean 371 Posted February 28, 2007 Author Report Posted February 28, 2007 k thanks a lot for your help! A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
