300A fuse:
There's a little plastic thing inside, should I take it out?
I had to cut so many strands off of my 0 gauge knu flex wire just to get the wire screwed in.
I swear I should have just done the big 3 without this damn fuse.
Edited by moh.vze.com
300A fuse:
yes
BRENT
1997 GMC Yukon
1-DC xl18"
Stetsom 2K5E
3-Kinetik HC1800's
1967 Pontiac GTO
damn bro i didnt have to cut ANY of my knu fleks to fit in. it is a very easy thing to do man. just attach the fuse with the two bolty looking thing. easy bro
2004 Chevy Tahoe LT........... THINKING
easy as 1..2..3
Oh and here are some tips to remember when connecting the wire to the fuse holder, you should loosen the screws all the way so there is a perfect circle for the wire to slide in. When you strip the 1/0 try not to mess with the wire strands as much as possible so they don't get tangled in each other therefore making it harder to slide into the fuse holder. Twist the wires in the same direction as when they came out of their plastic jacket then and as you are sliding them into the fuse holder you need to spin the fuse holder in the same direction as you twisted the wires. This will save you lots of frustration and the more strands you dont have to cut the better.
OH!!! I forgot the most important thing...dont forget to slide on the plastic end caps on each wire before you connect them to the fuse holder...nothing more frustrating then having to take off your perfectly connected wire just to slide the cap on and then the second time you have to cut half the wire off to make it fit back in lol.
Edited by eliassami5
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
easy as 1..2..3
Lol. I didn't get to read this until after I was done :(
Mistake #1: My 0 gauge wire was too thick that I couldn't get that alen head all the way down so that I can slide the piece all the way in. As a result, I took out the wire and it was a big mess. I had to cut a crap load off just to get it back in.
Mistake #2: I forgot to put the end cap on one of the sides so I had to redo that crap :(
Nonetheless, I've finished everything and got the Big 3 done!
I will check my voltages tomorrow on music. Right now it reads 14.5 volts with the engine on (at the battery but I think it read the same without the big 3).
Quick question: These fuses don't have polarity right? ~_~
