troy Posted April 22, 2009 Report Posted April 22, 2009 could i hook up the wire to the amp terminals along with power and ground wires?. to actually showme what voltage the amps see retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
SubSonic Posted April 22, 2009 Report Posted April 22, 2009 Depends, if u have a meter that change ranges, then yes, cause usually u measure 12V, in 1.0, since amps are 1000+ u need to measure, .100, or etc.. Re Audio Diamond Audio Alpine Audio Rocksford Fosgate DB Link
troy Posted April 22, 2009 Author Report Posted April 22, 2009 you do mean on he input side right? retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
troy Posted April 22, 2009 Author Report Posted April 22, 2009 i wanna measure voltage going into the amp retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Got_Bass89 Posted April 22, 2009 Report Posted April 22, 2009 Yes hook up meter to power and ground at amp is fine... Other guy talkin bout amp output voltage for some reason... Passport Build Here Alarm: Prestige APS997A 2-Way/Remote Start HeadUnit: Pioneer DEH-P6000UB Front Battery: Yellowtop Optima D34/78 Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH Subs: 2x DC Lv4XL 18's Amps: 2x Sundown Saz1500's Strapped Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube) Pillars: AudioBahn AS31Q Front Doors: Clif Designs TX40.5 Back Doors: Clif Designs CD50.4C Rear Speakers: Clif Designs TX46.5 Front/Rear Amp: Kicker ZX350.4 Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4) Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
