Pokey Posted February 8, 2007 Report Posted February 8, 2007 Hang on and I'll show you a picture...lemme find it real quick.
alpine Posted February 8, 2007 Author Report Posted February 8, 2007 ok BANNED LIKE A MOTHAFUCKA IM BANNED BECAUSE IM A FUCKIN FUCKTARD
01xtreme Posted February 8, 2007 Report Posted February 8, 2007 drill a hole just big enough to fit the wire through and push it through. then just seal up the hole. My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon...
ChevyBoy Posted February 8, 2007 Report Posted February 8, 2007 drill a hole just big enough to fit the wire through and push it through. then just seal up the hole.or do it the right way with a grommet.
Pokey Posted February 8, 2007 Report Posted February 8, 2007 Ok, see the bolts in the box under that amp....you go, from the inside, nut, washer, wire, washer on the inside....then on the outside, from the box, washer, wire, washer, nut. I believe that is how he did it, if not, someone correct me please.
ChevyBoy Posted February 8, 2007 Report Posted February 8, 2007 i would go. bolt, washer, terminal, washer, nut, wood, nut, washer, terminal, washer, nut, nut. might be a little excessive, but eh o well.
Pokey Posted February 8, 2007 Report Posted February 8, 2007 Same concept, you'd just use more stuff. And I agree with that way too...a lil extra doesn't hurt.
ChevyBoy Posted February 8, 2007 Report Posted February 8, 2007 hell, maybe even a lil thread locker lol.
Pokey Posted February 8, 2007 Report Posted February 8, 2007 True, wouldn't want anything coming loose back there.
SPLGEO Posted February 8, 2007 Report Posted February 8, 2007 invert the subs lot easer :watsup: 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
