The Saturn: Cant Stop There (dual 18's Upgrade)
Thanks mane :)
Im pretty excited...should be structurely done tomorrow, may even mount the 1st sub and the amp + get everything set up for the 2nd sub to arrive.
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
I went and got the birch I need to make the top of the enclosure and it looks like the enclosure is gunna be about .5" above the window line :(...not that it really matters I was just trying to keep it at the window-line
Pics tonight and will probably have the first sub mounted before the top goes on and will get some a$$ shots of it :)
Team Tupperware
god speed little buddy
R.I.P!
(Nov-29-2009)
92 explorer
current build
Lol thanks. And I didnt see your Q about the terminals...theyre about 4.5" long x 2" tall rectangular I'd say
Team Tupperware
what size speaker wire you running there
R.I.P!
(Nov-29-2009)
92 explorer
current build
8 gauge inside the enclosure, 4 gauge outside :)
Team Tupperware
Thanks :) but there is no amp rack really, lol..just going to double-layer the back of the port and mount it to that with some rubber washers on the mounting points probably.
And I just got the first sub mounted and it looks awesome...got some nice a$$ shots of it with the top still off. Pics tonight :)
Team Tupperware
Alright, almost finished :) Just as long as FedEx delivers the 2nd sub at a decent time tomorrow it should be in and playing tomorrow :D
But here's what went on today..
Got the mounting areas of the subs painted black tolook a bit cleaner once the 3rd baffle goes on..
Posted Image
Posted Image
Shots of the sub..
Posted Image
Posted Image
Lol, yea..
Posted Image
Posted Image
Posted Image
Posted Image
Panel mounted on the back of the port then another layer ontop of it (amp will be mounted here)
Posted Image
Team Tupperware
Top going on..
Posted Image
Posted Image
Posted Image
Inside the enclosure making sure everything's sealed and glue wasnt running everywhere..
Posted Image
Inside the enclosure..(pretty comfy, actually. lol)
Posted Image
2nd layer ontop of the enclosure..
Posted Image
Where it sits waiting for the other sub...
Posted Image
Pics tomorrow of the other sub (hopefully it comes in, im gunna be pretty bummed if it doesnt..) mounted and everything finished up (amp mounted etc. etc.)
Team Tupperware
