Speaker Wire Size For Front Stage
bobonit
Not sure if this should go here or under electrical, but here goes.
I'm going to be running my wires soon, so I guess i need to start buying some. I'd like to use the Knukonceptz Karma SS speaker wire. I need to know what size I should be buying. I'm running 3 SAX-100.4D amps at 4ohms/4 channel so 100 overrated watts per channel. Sundown E8's for midbass, Tang Band 6.5 for mid and Seas Neo Tweets. Is the 16awg good enough or do I need to go up to 12awg? I know I'm not running tons of power, but I was wondering how much impedance loss I would be getting since the amps are in the trunk and the speakers up front.
thanks.
97 Maxima SE
Bunch of shit going in, check out the build
I always run 14 gauge in my rides for my mids and highs I really like to use Monster 14 gauge 4 conductor wire so I don't have to make two runs and it's all in one jacket it works out slick.
The Shoe Maker without shoes!
Did a little more searching, I think I found my own answer. In the Wire/Fuse Guide under the electrical section it is showing for a 4ohm load I'm ok as long as I'm under 300 watts so I think I'm good there.
16 gauge: ~8.7 amperes
8 ohms - <600 watts
6 ohms - <450 watts
4 ohms - <300 watts
3 ohms - <225 watts
2 ohms - <150 watts
1 ohm - <75 watts
97 Maxima SE
What sucks is Knu only has 12 or 16.
Use 12 then :8)
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Overkill on wire size wont hurt, but not big enough will. Go with 12 gauge.
The System In Progress
Headunit: Pioneer DEH5800MP
Sub: DC Sound Lab Level 4 15" D2
Box: 4 cubes at 33Hz
Sub Amp: Cadence Z1200
Front Stage: PG RSD5cs
Rear Stage: Pioneer TSA6991R (Temporary)
Front and Rear Amp: Cadence TXA3004 (FS) (Looking)
Wiring: XScorpion, American Bass, Stinger Custom Pro 4 Gauge
  • Who's Online   0 Members, 0 Anonymous, 1409 Guests (See full list)
