Thumpper's Quad Ssa Xcon Ground Pounder Build Log
a little coat of primer to show off the flaws....this thing should be finished tonight
(except for the amp rack covers)
it will be going in for upholstery to match the door skins once my number comes up
so I'll be testing it out as is for a couple of weeks
Posted Image
Posted Image
Posted Image
Posted Image
did a test with the amplification and x-overs for the JBL 660 GTI components in the doors
the amp rack cover will clean things up nicely.....
I replaced the Soundstream Powerplant and upgraded to two Tsunami digital fuse blocks so there will
be a digital display on the amp rack for Voltage
Posted Image
Posted Image
Wow. Simply amazing, you do such good work man it's ridiculous. I've looked at your other thread with all the customer builds, and I have to say you are the man, and a great inspiration. Keep it up I'm totally tuned in
1997 Pontiac Bonneville Black on Black on Black
15" DC Sound Labs Level 5 w/ quad coil in a T-Line tuned to 35 hz
7" Jensen VM9311TS Touch Screen Flip Out w/ J-Link
Blue Custom Trim
Blue Custom Fiberglass Rear Speaker Pods
Autotek Mean Machine MM2000.1
1/0 Knukonceptz KLMX
Rockford Fosgate Twisted RCA's
2 Audiopipe Anl fuse holders w/ 200A Kicker fuses
2nd battery (Soon to be an Odyssey D3100)
Dynamat Extreme Bulk Pack
Custom False Floor
15% Tint All Around
Custom Painted Stock Rims
My Build Log
Tailights
15" Lvl 5 DC T-Line Build
you best be at one of the big shows in bc this year i hope to see this thing in person
R.I.P!
(Nov-29-2009)
92 explorer
current build
everything is installed except for the power/grounds and doors.........
this is hoe I'll be running it untill I am able to get the enclosure in for vinyl
and the amp rack covers and tweeter pods for the pillars are still to come
doesn't look to bad for being primer........
Posted Image
Posted Image
Posted Image
Posted Image
it took a whole 250ft roll of 12 gage to complete the runs to the doors and pillars..
ran out of Zip Clips...... :bull: ....the rest will have to wait till next weekend.......................... I have to go build Glens enclosure now.....
Posted Image
Just the looks I guess. I would not buy them based on the way they look now and a couple other reasons but I am glad You are happy with them.
How do they sound and how many watts are you running to yours?
They are quite expensive to build, trust me.
