moh.vze.com Posted April 30, 2009 Author Report Posted April 30, 2009 Got my volt meter hooked up. It took me 3+ hours wow. Took a while to get the wire run through the carpet and to the trunk. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
runwitbass Posted May 2, 2009 Report Posted May 2, 2009 wow .. you using 14 gauge wire .. i went to home depot and got some 22 gauge wires .. dunno why but figure since the wires on the stinger volt meter were so small i'd use the same size or so but 22 turn out to be a little too small too but non the less worked for me .. lol .. and i found a stinger volt meter on ebay for $22 buy now and like $6 shipping .. jus puttin it out there .. but works good jus gotta adjust it a little .. 1 12" T3 Audio TSS saz 3000d sax 125.2
moh.vze.com Posted May 3, 2009 Author Report Posted May 3, 2009 wow .. you using 14 gauge wire .. i went to home depot and got some 22 gauge wires .. dunno why but figure since the wires on the stinger volt meter were so small i'd use the same size or so but 22 turn out to be a little too small too but non the less worked for me .. lol .. and i found a stinger volt meter on ebay for $22 buy now and like $6 shipping .. jus puttin it out there .. but works good jus gotta adjust it a little .. I got mine off Darvex to support the guy =] Does ebay have insurance? DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
runwitbass Posted May 5, 2009 Report Posted May 5, 2009 I got mine off Darvex to support the guy =] Does ebay have insurance? not sure but i got mine fine .. lol 1 12" T3 Audio TSS saz 3000d sax 125.2
zaxfire69 Posted May 5, 2009 Report Posted May 5, 2009 Is yours accurate? Mine is the Red one and is off by about 1 volt. I may end up buying the blue one.
runwitbass Posted May 5, 2009 Report Posted May 5, 2009 Is yours accurate? Mine is the Red one and is off by about 1 volt. I may end up buying the blue one. you can always adjust it by opening it and adjusting the yellow thingy .. i adjust mine to a frends cig lighter volt meter .. lol 1 12" T3 Audio TSS saz 3000d sax 125.2
zaxfire69 Posted May 5, 2009 Report Posted May 5, 2009 Mine won't adjust high enough. I can adjust it all the way up and still won't match my Voltage. If my Voltage was 13.0 volts resting. On the meter as high as I could adjust would be 12.0 volts. Then when I would turn on car it would be 13.8. Go back to my battery and check with DMM and I would be @14.4 Volts. Still off by a few volts. I bet I got that reject voltmeter.
runwitbass Posted May 5, 2009 Report Posted May 5, 2009 Mine won't adjust high enough. I can adjust it all the way up and still won't match my Voltage. If my Voltage was 13.0 volts resting. On the meter as high as I could adjust would be 12.0 volts. Then when I would turn on car it would be 13.8. Go back to my battery and check with DMM and I would be @14.4 Volts. Still off by a few volts. I bet I got that reject voltmeter. yea you might've gotten one of those TARD volt meter .. read bout soem of those on CA.com . lol . but when i got mine .. jus wired it up and i was off like bout 1 volt .. adjusted it and im pretty much right where i should be .. but then again it might not even be your voltmeter .. where did you wire it up at? . i jus wired mine from my eq which had those 3 wires too . + - rem . 1 12" T3 Audio TSS saz 3000d sax 125.2
moh.vze.com Posted May 5, 2009 Author Report Posted May 5, 2009 My stinger blue led volt meter was pretty accurate. You might have gotten a defected one. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
runwitbass Posted May 10, 2009 Report Posted May 10, 2009 Mine won't adjust high enough. I can adjust it all the way up and still won't match my Voltage. If my Voltage was 13.0 volts resting. On the meter as high as I could adjust would be 12.0 volts. Then when I would turn on car it would be 13.8. Go back to my battery and check with DMM and I would be @14.4 Volts. Still off by a few volts. I bet I got that reject voltmeter. hmmm i dunno now .. i seem to be having your problem too now .. i wonder if leaving it on too long has anything to do with it .. probably not ..lol . but my volt stops at like 13volts only now .. meaning i adjusted it to the max and thats all it'll go to .. hook up my frends cig volt meter and it says 14 with car on .. and on the stinger .. like 12volts .. maybe i got one of those TARD ones too or the damn thing jus SUCK .. lol edit: and when i first got the volt meter .. everything was fine .. 1 12" T3 Audio TSS saz 3000d sax 125.2
