Remarkable Flex Posted April 28, 2009 Report Posted April 28, 2009 If the frequency response on an amplifier is 35hz, and your box is tuned to 32hz, your subs can play below 35hz, and everything else like wiring, head unit and you get the point is correct. Does this mean your connections to that amplifier will not play below 35hz ? Just a question i've been pondering
Boon Posted April 28, 2009 Report Posted April 28, 2009 Uhh, what? I think you have your terms wrong... and if you don't, 35hz is a terrible frequency response for an amplifier and I would throw it in a bin if that's what mine did... 10.x volts fo' life!
Remarkable Flex Posted April 28, 2009 Author Report Posted April 28, 2009 Nope, I don't this is what I saw when my friend showed me an amp he wanted and I told him to wait so I could get some input from people here. Low Frequency response: 35 Hz High Frequency Response: 250 Hz Note: This is an amplifier.
Decaf Posted April 28, 2009 Report Posted April 28, 2009 likely that means a lpf and hpf 35hz-250hz for the low pass and 250hz-4000hz or something like that thats what im guessing u are trying to explain... but i dont really know what ur asking... its not gramatically correct or using the right words.. lol the lowpass filter on the amp should be set at ~80hz the highpass wouldnt need to be used because there should be a switch for lp/full range/hp (im guessing this is a 2channel or 4channel)
Boon Posted April 29, 2009 Report Posted April 29, 2009 If that's actually the frequency response then it's a horrid little shitbox. What sort of amp is it? 10.x volts fo' life!
