uhoh_45 Posted April 28, 2009 Report Posted April 28, 2009 so i have 2 sets of bassworks 6.5s as my rear channel and then a set of 5.25s in my doors as my other 2 channels on my DD C4 amp and was wondering if it would be ok running the 5.25s and 6.5s on the same channel there all single 4 ohm mids so i guess my question here is, is it ok to run 2 6.5's and a 5.25 on the same channel ? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
uhoh_45 Posted April 28, 2009 Author Report Posted April 28, 2009 i know im bumping it early just would like to know so i could get out and get it wired up or look into a new amp R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
troy Posted April 28, 2009 Report Posted April 28, 2009 as long as the speakers are mired to an impedeancethe amp can handle then yes. retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
