so im building my astro i have 2 PBX ES 15D - 15" and will be powered by one PBX ASA-1500.1D amp..speakers are powered only by stereo for now..so im only gonna have one amp on the car...do i need an extra battery?. i can get a 2 farad capacitor..would that be enough?..im not looking to win competitions or anything like that just want to have some :hairtrick: in my car lol..
Edited by aquito
Guest KyleCannon
You could get away with it in my opinion. I was running more than that on stock electrical and a costco battery. But that's just my 2 cents.
Throw an hc1400 up front and call it a day! my 97 astro has the original alternator on it and it's around 12 years old now.... Solid little beasts, as far as the battery put a stronger one up front and it should work out just fine. You can still add the cap at a later time if needed.
Edited by Soulman07
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
will it help if i use 0 gauge cables? or 4 gauge would be ok? and for the subs 8 gauge right?
0 guage is the only way to go especially when running much over 1000 watts over a length of the vehicle off the stock battery and alt.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
The astro engine is so compact and small as far as the runs from the alt to battery and ground ect... I don't think you'll notice a difference to be honest. The factory wire on my astro was 4 gauge. Running 0 gauge to the back I would recommend. 8-12gauge for speaker wire
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
ok cool...so if i run from the stock battery 0 gauge to the amp and have a 2 farad cap i would be ok...is the cap gonna help at all? where can i get cheap 0 gauge cables? how much cable should i buy? 25 ft ok or too much?
Edited by aquito
you should deff be good with what you got. if its one amp you are fine, its not tremendous power but will do the job, and as long as thats all youre runnin have no worries. now once you add another amp for your mids and so on you will need some more power, until then just sit back and relax while the bass hits.
theres always work in progress
wouldnt even worry about a cap.....just my belief....but they are just over priced volt meters.
Edited by stretchnutz78
  • Who's Online   0 Members, 0 Anonymous, 782 Guests (See full list)
