kylecm85 Posted May 2, 2009 Report Posted May 2, 2009 if those are good then i would take the amp out and just bench test it to be sure its in the amp and then if it is u will have to send it off to get fixed. Quote 94 lincoln mark viii h/u: kenwood kvt 614 Excelon comps: alpine type x amps: mtx 1501d mtx 4004 sub:2 DC lv4 12 wiring jl audio 0awg 8 awg sub jl audio 4 awg for mid and highs amp myspace.com/kylecm85 carstereolexington.com
robbor6386 Posted May 2, 2009 Author Report Posted May 2, 2009 all right thanks for the help guys. ill try the bench test but if its something i cant repair it really aint worth sending out a 7 year old amp when i can buy a new (shittier) one for the cost of the repair Quote Eclipse AVN7000 MTX 5604 for components MTX TXC 6.1 components Autotek MM4000.1 (Sold) 8 15" Kicker CVRs (Sold) 2 Optima Yellow Tops
robbor6386 Posted May 2, 2009 Author Report Posted May 2, 2009 i just did the bench test and the power and protect light both are blinking back and forth. anyone else had this issue or know what it is? Quote Eclipse AVN7000 MTX 5604 for components MTX TXC 6.1 components Autotek MM4000.1 (Sold) 8 15" Kicker CVRs (Sold) 2 Optima Yellow Tops
Boon Posted May 2, 2009 Report Posted May 2, 2009 Power supply is probably fucked. Check the resistance between the power and ground terminals (obviously you'll have to check on one side of one of the fuse holders), if it stays at 0 then you have bad FETs in the power supply. If you have the back off it, check the main power rail caps (there's 2? big ones). If the tops are really bulged or there's evidence that they've leaked that'll be what's caused your problem. These amps were BADLY prone to it. Quote 10.x volts fo' life!
Stallion Marauder Posted May 2, 2009 Report Posted May 2, 2009 (edited) I had that same amp and i had nothing but problems with it! It would always go into protect even the first day i got it! It did put out some serious wattage but again that amp would overheat so bad youl burn your hand touchin it! Edited May 2, 2009 by Stallion Marauder Quote 2003 Mercury Marauder Black (R.I.P) Tinted Windows Purple HID's 10000K Fog Light HID's 10000K Swi Jack Steering Wheel Controls Apple I-Pod Classic 80GB Alpine KCE-422i Full Speed I-Pod Cable Alpine IVA-W203/P1 Navigation/Bluetooth Alpine PKG-M780 7' Headrest Screens Alpine PXA-H701 Sound Processor Alpine MRP-F300 4 Channel Amp Rockford Fosgate 1501bd Power Amp 2 Kicker L7 15' Solo Barics Alpine Type R SPR-17S Component's Alpine Type R SPR-57C Coaxial's Monster Performance RCA's 0/2 Gauge Wires BIG III W/Fuse 200 Amps Custom Built Alternator Yellow Cap Optima Battery Front Xstatic Batcap 800 Back Custom Mounted Bass Knob LED's 2x License & Trunk Light BoYo VTK-350 Color Backup Camera Dynamat Xtreme Front Doors & Rear Deck Clifford Matrix 50.7X Alarm System/Remote Start
