Bondo On The Inside Of Sub Box
Has anyone used bondo to seal up the seams on the insideof the box?
i have... the bondo tends to crack so i wouldnt recommend it for sealing seams... id just use caulk... or glass it
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
X2 bondo cracks easy and would be all over the inside your box
R.I.P!
(Nov-29-2009)
92 explorer
current build
A couple of my SPL boxes have had bondo/milkshake in the corners but they also had a shitload of glue, screws, resin and 45's. The bondo was just there to smooth it out before it got more resin poured on.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 961 Guests (See full list)
